Results 1 to 10 of 16
Thread: Clicking/Rattling in glove box area
    Belfast
    Default Clicking/Rattling in glove box area
    Diving home last night I passed a car who's exhaust was belching out plumes of white smoke.
    I hit the switch to change from outside air in to re-circulate interior air and once i switched back there was this loud clicking/rattling which went on very constantly for about 10 seconds then disappeared
    Tried switching back and forwards a couple of times to check but it happens every time!
    It also happened this morning when I unlocked the doors with the remote fob.
    Anyone any ideas? I had thought it obviously something to do with perhaps a motor for switching over the air from external to internal but the door opening scenario has me really confused now!
    Any thoughts or experiences with similar?
    Alan
    Mileage : 000
    Yes the recirc motor has lost one of it,s teeth. If you do a search you will find the information you need. Have a read of this.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    And if you don't sort it (either replace or unplug it) it'll carry on clicking every 20 minutes or so.
    Surrey
    Yep seems to be a very common problem.
    Mileage : 000
    I paid about £60 trade for mine, and they are a BIT of a pig to fit. Well to get to the screw at the back is anyway.
    Surrey
    So I have heard Ed. Perhaps you can do a how 2 a18nmk.
    Mileage : 000
    Quote Originally Posted by steve1975l View Post
    I think you might have a good idea there. It seems to be a common fault. I will try and do something to sort this out. But if anyone with this problem does a search there is quite a lot of information how to remove both the glove box and the "offending item" the servo motor. from the photo I put up on the " link" it gives a very good idea of what needs to be done. all you need is a lot of patience and dextrous fingers to remove the screw at the back, ( lieing on your back with asmall torch in your mouth it is possible to get the " difficult" screw out.
    Lincoln
    Anyone know the long term effects of this problem? Mine's been doing this now for a couple of years. I don't use the aircon too often, and apart from the comedy factor when it does it in front of visitors at random, I don't seem to notice any adverse effect. The aircon is still fine (i.e v. cold) and everything else still seems to work OK so I've just left it clickin' !
    Mileage : 000
    You could remove the glove box and unplug the "offending" servo motor.............. All will be silent then.
    Lincoln
    Quote Originally Posted by ed taylor View Post
    Mmm..Thanks Ed, Could do, but it doesn't bother me and everything still works OK.
    What would I notice packing in functionally if I did as you suggest?
  1. clicking noise drive belt area
    By hairy31 in forum Engine & Drivetrain
    Last Post: 28th May 2012, 22:50
  2. Weird clicking noise from heater control or glove box
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 14:29
  3. Weird Clicking / Rattling
    By spida_singh in forum Insignia car chat
    Last Post: 16th April 2010, 23:34
  4. Clicking/Rattling on Full Lock
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2010, 09:51
  5. clicking noise from behind glove box???
    By mick 1986 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 12:58
