Results 1 to 10 of 22
Thread: Warranty - Is it worth it - 2.2 Direct SRI 06
    Blantyre
    Default Warranty - Is it worth it - 2.2 Direct SRI 06
    £208.9612 Month Dealer Wrap
    Warranty Direct
    12 month Warranty Direct protection with no Dealer warranty available
    For details of cover see Policy Document
    The items under the following list are covered. Any item not specifically mentioned is not covered.
    ENGINE
    Cylinder head
    Cylinder head gasket
    Valves (excluding decarbonisation, burnt or pitted valves and valve seats)
    Valve springs
    Valve guides
    Camshaft and bearings
    Cam followers
    Hydraulic lifters
    Push rods and rocker gear
    Timing gears
    Chains
    Belts and tensioners
    Pistons
    Piston rings
    Cylinder liners and linear seals
    Connecting rods and bearings
    Gudgeon pins
    Crankshaft and bearings
    Oil pump and oil pump drive
    Distributor drive gear
    Distributor drive
    Flywheel and ring gear
    Flex plate/auto drive plate
    Inlet and exhaust manifolds
    TURBOCHARGER
    Internal failure of factory fitted turbocharger and wastegate.
    GEAR BOX: MANUAL AND AUTOMATIC
    Gears
    Shafts
    Synchromesh hubs rings and selector shafts and forks
    Extension shaft
    Torque convertor
    Automatic transmission clutches and brake bands
    Oil pump
    Bearings and bushes
    Valves and valve block
    Governor and servo.
    TRANSMISSION
    Crown wheel and pinion
    Differential gears and bearings
    Bushes
    Half shaft and half shaft bearings
    Driveshafts
    Bearings and constant velocity joints
    Propshaft universal joints and centre bearing hubs and wheel bearings.
    Only the components originally fitted as standard by the manufacturer are covered unless agreed in writing by us
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I was looking for one of these but decided to leave it
    Blantyre
    I wasnt bothered mate, but now am thinking again
    Apr 2008
    Liverpool
    Quote Originally Posted by spennny View Post
    Ahh I see whats made you change your mind?
    Blantyre
    Quote Originally Posted by Sean-2.2Direct View Post
    This place
    Apr 2008
    Liverpool
    This place
    I see I was thinking about it when reading though the threads but then decided against as it would probably be very hard to claim the money back if anything did go wrong.
    So far I have been fine up to 40k now had it a year and a half bought it on 11k Touch wood I will have infinit trouble free miles
    Blantyre
    Am on 43k just now, maybe i will just leave it, the car has been fine up till now, nothing wrong at all, so think i will just continue to stick some cash away each month and use it if needed
    Apr 2008
    Liverpool
    That will probably be the best thing to do at least you will have some cash behind you if ( You know what ) Decides to go
    Blantyre
    I have some kind of warranty with the AA, i will have to check that out, just remembered there
    I am looking at Tesco Finest Plan £339 pa or Network Q at £350 pa but open to sugestions ....... http://www.tescofinance.com/personal...c.jsp#sectionc
  1. Warranty Direct.
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2012, 21:10
  2. Car Warranty - Is it worth it?
    By conner in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 16:49
  3. Warranty Direct or AA Warranty
    Last Post: 20th March 2010, 12:31
  4. AA warranty - is it worth it?
    By wardy in forum General Chat
    Last Post: 6th December 2008, 00:32
  5. Network Q Warranty Plus. Is it worth it?
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2007, 21:02
