Results 1 to 7 of 7
Thread: Signum Speakers
    May 2009
    Devon
    Default Signum Speakers
    Can anyone help? My (new to me) 04 Signum has a CCR 2006 radio/CD/tape. Only the speakers on the driver's side work (and I am not sure all of those do - the big one in the door definately does). When I wind the balance over to the passenger side, absolute silence. Can anyone point me to a likely connector or other gizmo which I can test/tweak or something else I cvan do to get stereo back?
    Sunny Dartmoor
    I'd remove the stereo and see if all the wires are intact and try some continuity checks between the back of the stereo and the speaker connections,hth........
    May 2009
    Devon
    Thanks - sorry to be so iggerent but where do I start in removing the stereo? not too bad at the oily bits but trim and electrics are a closed book to me. I just do not have as clue where to start.
    Jan 2009
    WGAF#5
    there are 4 torq screws in the corners of the unit -remove these then cut a coat hanger (metal) into 2 long strips - bend them in half - push each end into the holes and slowly wiggle - the head unit should them come free - the only thing is the radio connectors are generally "fixed" to the rear of the cage - so it should be connected IF the radio is sitting flush
    when you take it out the loom connector should be in the top left corner -make sure its seated tightly in the radio cage
    hth
    regards
    Dez
    May 2009
    Devon
    Thanks - that is just what I needed. I will try it now.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    try makin shore the balance is ok first lol
    May 2009
    Devon
    The balance is what showed the problem - wind it to the passenger side and nothing!
  1. speakers
    By crofty76 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2012, 20:56
  2. signum speakers wire colours
    By neilb1 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2011, 00:10
  3. New signum speakers
    By DHobbs in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 11:49
  4. Changing the Speakers in my Signum 07?
    By Billybb in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2009, 16:28
  5. speakers from gsi
    By adfrodsham in forum Parts for sale
    Last Post: 9th May 2009, 16:56
signum where is te 9th speker
half speakers working on signum 04
