Results 1 to 10 of 17
Thread: hid kit problem URGENT!!!
    inverness
    Arrow hid kit problem URGENT!!!
    hi guys im new to this site but have a question?
    I have fitted a hid kit from diane-shop and fitted to the car. when turned on the bulbs flicker. so i fitted a relay kit which takes the power direct from the battery. still flickers!!!
    what else can i try to stop the bulb check?
    can it be turned off with the aid of op-com?
    Sunny Dartmoor
    You can either buy some cancellers or have your car tech2'd to change it to Zenon headlights,i think the cancellers are the cheaper option,hth.........
    inverness
    where can i get them from? can it be turned off with op-com?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The lights will always flicker, you need to fit capacitors to prevent it happening. The bulb check also needs a resistor to be fitted.
    Do a search on here and you will find all the details, it's been posted many time before...
    Sunny Dartmoor
    Ebay m8,no it has to be Tech2 at your dealer.
    edinburgh
    warning cancelers.....stops the warning and the flicker...... sometimes listed on ebay as canbus warning cancelers
    edinburgh
    .....no need for tech 2, resisters or capacitors, cancelers incorperate all this
    inverness
    i bought this
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1
    i thought this was meant to stop it happening?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by fbsd View Post
    Yes, the cancellers are resistors and capacitors in a box, with a price tag to reflect that someone has boxed it up ready for you.
    I even did a circuit diagram for what the cancel box is, and it's very simple indeed.
    Here
    http://www.vectra-c.com/forum/showth...circuit&page=3
    You will need one per light unit
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    That Ebay item is just a relay wiring, not cancellers.
  1. URGENT! Help needed common problem H.I.D
    By MWVEC in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2011, 22:15
  2. the problem nobody can find!!!! REPLY URGENT
    By nickvectra in forum Engine & Drivetrain
    Last Post: 22nd June 2009, 11:10
  3. urgent alternator problem i think
    By dan1983 in forum Engine & Drivetrain
    Last Post: 15th May 2009, 18:21
  4. Astra G 1.8 SRi Alarm Problem URGENT!
    By aaruck in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2008, 13:00
  5. Urgent help required - H.I.D fitting problem
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2007, 10:29
