Results 1 to 10 of 11
Thread: Spanner warning Light
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Exclamation Spanner warning Light
    Hi,
    just hoped into my 05 1.9 CDTI Signum today turned the key and the spanner light with the car behind it come on, as soon as the engine has started the light goes out.
    she starts fine, drives fine no loss of power, this light comes on if the engine is hot or cold.
    any ideas
    thanx in advance
    Sam
    Apr 2009
    Bournemouth
    quick update, called AA out to have a look. they done a computer check and came back with no codes.
    so does this mean the error has cleared and i have to wait for it to go. or is there more to the puzzle?
    11 Post(s)
    If the light stays on until the engine has been started, then this is indicating a fault code is stored in memory. Maybe the AA code reader wasn't compatible with your car.
    As long as the light goes off once the engine has started, then there are no faults. It'll take a number of clean key turns or 'x' days before the fault code will self delete.
    Apr 2009
    Bournemouth
    do you know of a good scanner to read theres spanner lights at reasonable price.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    do it for free, no code readers necessary!!!
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Aug 2007
    Thumbs up
    as far as i remmember the spanner light with car behind means that the car has done 20k (not sure how much) since the last service. Nothing to worry about and you can remove the light yourself (there is somewhere instruction in this forum).
    11 Post(s)
    Quote Originally Posted by troodon View Post
    Nope. Car/spanner light is a fault light.
    The ECOService Flex warning light is a picture of an oilcan with a spanner through it. And on newer Vectra-C's it's the word "InSP" that comes up in the odometer display briefly when you first turn the key.
    Aug 2007
    yeah, my bad then
    Jun 2009
    Wales
    Mine has been on all the time for the past two months now, no problem with the car it still runs ok, but cant get rid of it does anyone know hoow to do it, i have tried holding in the mileage button and starting the car but that wont stop it
    Regular Member Swaite53's Avatar
    South Wales
    Holding the mileage button dow as you said, only clears the service indicator, which is an oil can, not the spanner. If the spanner is permanently lit, it means the car has registered a fault. If you disconnect the battery for 30 minutes, then reconnect, it should clear the code. If the porblem was a glitch, it should stay off. If the problem is still there, the light will come back on.
    There is a way to read codes for free:
  1. Car with spanner warning light
    By Handles Sri in forum Engine & Drivetrain
    Last Post: 26th October 2012, 14:52
  2. Spanner Warning Light
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 18:13
  3. Spanner warning light
    By olearysp in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:41
  4. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
  5. Car with spanner warning light
    By DennisTheMenace in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 07:47
vectra car with spanner warning light
car and spanner warning light vectra c
vauxhall vectra warning lights car with spanner
car with spanner warning light vauxhall vectra
Tags for this Thread
