Thread: Management light-no spanner
    Apr 2009
    uk
    Default Management light-no spanner
    I have the engine management light on after doing egr.
    Car runs perfect and there are no fault codes stored. Better than before in fact.
    How can i reset the light?
    The light should reset itself after any faults have been rectified.
    As its still on, it would suggest there is still a fault somewhere, although your code reader says there isn't. Hmmm.
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    most generic scanners will on read engine codes, i suspect their is an error other than that causing the spanner to come on
    Apr 2009
    uk
    No spanner just picture of engine
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    oh you mean the emissions light. That will come off if the EGR connector is plugged in properly. Happened to mine, had to reset mine with tech2 but a disconnect of the battery should sort it out as long as the EGR plugged is back in properly
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  3. 'Spanner' engine management light on 2.0Dti
    By Bigdrinks in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:50
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
