Results 1 to 10 of 11
Thread: dual exhaust
    Regular Member vanman's Avatar
    Abingdon Oxfordshire
    Default dual exhaust
    I would like to fit dual exhaust to my vec est.I also have the factory fitted stage 1 kit fitted .It is a 1.9 cdti sri on an 07 plate.Any suggestions.
    Cambridgeshire
    Go with a VXR kit mate I got the GM VXR kit from the CAT back and looks the dogs
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm getting a Vec estate myself and was thinking of getting something similar. VXR exhaust tips look great, I just need to know what needs to be done to make them fit?!?
    Leicester
    Vectra Estate use's the Signum rear exhaust lay out which is totally different from the hatch and saloon.
    You should be able to fit the Signum 3.0 CDTi twin exhaust assembly with no modifications to fit, then you will need to have the exhaust tailpipes extended.
    It is cheaper to buy the Elite rear silencer assembly as it has the turn down tail pipes, then remove them and have exposed ones fitted on extended pipes.
    Should be a simple conversion.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    another vxr shot
    hope you gat a few more ideas aswell m8
    Bournemouth
    How much should one expect to spend on a dual exhaust ?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Maverick View Post
    It's a 3.0 Estate It has PDC on the rear....could that be a problem, because I see the guys here have the VXR difuser and no sensors on it
    Leicester
    Quote Originally Posted by Celes View Post
    You can mount the parking sensors in the VXR rear skirt. But you will be OK to mount extended tail pipes below your original bumper.
    Leicester
    Quote Originally Posted by Topspeed View Post
    Depnds if you want to buy new. The 3.0 assembly with sports tail pipes like I have is nearly £400 retail. The Elite version with turn down tail pipes is considerably cheaper.
    I would go down this route as you would be changing the tail pipes anyway.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Let's see if I got it right
    I will need to replace this bit with the VXR one, extend the pipes and mount the VXR tips on
    Then I'll have to mount the sensors there...?
  1. Dual exhaust
    By frigosolver in forum Styling
    Last Post: 16th February 2012, 20:33
  2. vec c gsi dual exhaust
    By tappetpaul in forum Parts for sale
    Last Post: 3rd November 2010, 01:34
  3. Dual exhaust
    By Dippy-Vx-line Red in forum Styling
    Last Post: 6th March 2010, 17:42
  4. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  5. SRI dual exhaust
    By ryan j in forum Styling
    Last Post: 6th April 2008, 03:15
