Results 1 to 10 of 18
Thread: passenger window switches
    Regular Member old cruiser's Avatar
    slough
    Default passenger window switches
    Anyone know if the electric window switch assembly on the passengers side can be removed/ prised out without taking the door card off?
    Cheers Pete
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    yes m8 it popes out if you use a small block connecter screw driver
    slough
    Nice one , thanks mate
    Cheers Pete
    Regular Member Bethan39's Avatar
    South Wales
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    As Rich says easily pops out and comes apart as i had to use some switch cleaner on mine as it totally stopped working quick spray let it dry rebuild job done!
    slough
    Quote Originally Posted by Bethan39 View Post
    thanks mate, pretty much what happened to mine, exercised the switch and seems to work albeit slightly intermittent, but will try and get it out and do what you did with the switch cleaner, strange how that side packed up whereas the drivers side bank are fine, I guess due to it getting more use.
    Cheers Pete
    Regular Member PORKBALLS29's Avatar
    Epping
    Mine is the same. Although looks like some one has had to do this previously and butchered the switch. But its added to the list of things to do.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    I saw this thread 10mins agi and have literally gone outside and whipped it out the car! so now got the switch to pop out the "faceplate", can i strip it further without breaking it? I've caked it in switch cleaner thus far...
    slough
    Just wanted to clear something up; was it definatly the passenger side switch assembly that you removed without taking door card off? as just looking on TIS and it states that the door card needs to be removed when removing passenger side switches but drivers side can be just prised out!!
    Cheers Pete
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    nah m8 it deffo just pops out.hth
    Apr 2009
    Stevenage, Herts
    Cheers Pete
    Yup - just physically done it myself for the first time too. Be gentle so you don't mark it though.
  1. Window switches
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 17:30
  2. Window switches
    By VeccyMike in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2012, 00:42
  3. Window switches
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2012, 07:39
  4. Passenger door switches
    By brianjamesreed in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 19:57
  5. Passenger door switches
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2008, 19:21
how to remove vectra c window switch
vectra passenger window switch
vectra window switch
