Z20NET Turbo boost pressure.
Hi,
Can some of the more technically minded amongst you assist with this query. I’ve purchased one of the Opcom code readers from fleabay and have been having a play around with it. As it can read and record live data I’d thought I’d go for a spin in my Signum (Z20NET) and record some info. I’ve always been curious as to what the boost pressure my turbo is currently kicking out and according to the data produced by the reader it is producing a maximum of 176Kpa. Converting that figure gives me 1.55bar. Now my question is this, what’s a Signum Z20NET 2003 plate supposed to be producing, boost wise?
PM duncan (admin) m8 he knows a hell of a lot of info about the Z20NET. HTH
thats about 21 and a bit psi if my science is correct sounds about right to me ....
Doh, I was always rubbish at maths.
176Kpa = 1.76Bar (give or take)
1.76Bar = 25.5Psi (give or take)
All pressure values read from the ECM transducers on my engines at work show absolute pressure values (to allow for use at varying altitude).
So if you are seeing a value of around 176kPa, with atmospheric pressure of say 102 kPa, your boost is really 74kPa / 0.74bar / 10.7PSI gauge pressure.
Phill
Thanks for the replies lads. I feel a bit more at ease now that you have explained the magic/maths.
Originally Posted by
phill77
Phill
Yep, that would explain it perfectly - the reading he's getting being an absolute one - and with the correction then coming out at around 0.7 bar then that's spot on for what it should be on a standard 2.0T.
