Likes Likes:  1
Thread: Z20NET Turbo boost pressure.
    Regular Member crabbitoldgit's Avatar
    Wetherby (Body) - Ayrshire (Heart)
    Default Z20NET Turbo boost pressure.
    Hi,
    Can some of the more technically minded amongst you assist with this query. I’ve purchased one of the Opcom code readers from fleabay and have been having a play around with it. As it can read and record live data I’d thought I’d go for a spin in my Signum (Z20NET) and record some info. I’ve always been curious as to what the boost pressure my turbo is currently kicking out and according to the data produced by the reader it is producing a maximum of 176Kpa. Converting that figure gives me 1.55bar. Now my question is this, what’s a Signum Z20NET 2003 plate supposed to be producing, boost wise?
    Full Member gibbon7000's Avatar
    lincs
    PM duncan (admin) m8 he knows a hell of a lot of info about the Z20NET. HTH
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    I'll do that. Thanks.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    thats about 21 and a bit psi if my science is correct sounds about right to me ....
    Doh, I was always rubbish at maths.
    176Kpa = 1.76Bar (give or take)
    1.76Bar = 25.5Psi (give or take)
    [Ex]Admin Duncan's Avatar
    I've edited your original post with respect to this thread - http://www.vectra-c.com/forum/showthread.php?t=70975 - which you may not have seen.
    With respect to your question, if you're running boost of 1.76 bar on a standard 2.0T then it's somewhat higher than it should be.
    A standard 2.0T runs around 0.7 bar (10psi), a BSR Stage 1 remapped 2.0T runs around 1.0/1.1 bar (14/15psi) and a Stage 3 runs around 1.76 bar (25psi) - so if you're running 1.4 bar then it's not right (understatement). Danger of things going with that.
    However, you say that youv'e got a reading of 176kPa on the kit you were using. Without knowing where that pressure was being read from i.e. what variable you were looking at then it may well be that you're not reading the actual boost pressure.
    Northants
    All pressure values read from the ECM transducers on my engines at work show absolute pressure values (to allow for use at varying altitude).
    So if you are seeing a value of around 176kPa, with atmospheric pressure of say 102 kPa, your boost is really 74kPa / 0.74bar / 10.7PSI gauge pressure.
    Phill
    Thanks for the replies lads. I feel a bit more at ease now that you have explained the magic/maths.
    Quote Originally Posted by phill77 View Post
    Phill
    Yep, that would explain it perfectly - the reading he's getting being an absolute one - and with the correction then coming out at around 0.7 bar then that's spot on for what it should be on a standard 2.0T.
  10. Likes minienis liked this post
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. z20net oil pressure switch
    By beat275 in forum Engine & Drivetrain
    Last Post: 28th February 2012, 13:05
  3. Turbo Boost Gauge on z20net
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 22:56
  4. Help with pick up points for turbo boost and oil pressure guages
    By Beebs in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 15:56
  5. z20net boost in psi??
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 16:48
z20net stage 1
z20net standard boost pressure kpa to psi
z20net bar
boost z20net
z20net boost pressure
ποση πιεση z20 net
what pressure should a vectra c turbo be running
z20net turbo pressure
vectra turbo 10 psi boost
z20net what turbo
signum 2.0 turbo boost
z20net forum
