Thread: help with steering rack gaiters
    Sunderland
    confused help with steering rack gaiters
    Hi,I've got power steering fluid leaking from within the drivers side steering rack gaiter,the steering is a little noisy,so has anyone had the same problem and any help would be greatly appreciated
    wilson002
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like you need a new rack m8
    Sunderland
    Default found this on ebay...
    Oh NOOOOOO!Thanks for that...
    been looking on ebay for steering racks/power steering stuff and found this;http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=140323132462
    has anybody used this?is it worth a go?
    cheers
    wilson002
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Hi Wilson002,
    I tried something similar on mine but it didn’t make any difference, it still leaked..
    You will in the end need to get a new rack fitted. The seal is gone it’s that simple I’m afraid.
    I did mine today wasn’t as terrible as I expected. But then I’m fairly good with the spanners and had a VW mechanic mate help me.
    I’m sure if you buy a rack most garages will fit it for you.
    I can assure you that the track rod arms will be knackered as the steering fluid damages the ball joint.
    Where steering is concerned its best to just replace the whole lot and start from fresh.
    Shopping list was Rack (£125), track rod arms (£20 each), track rod ends (£13 each) and lastly gaiters (£18 each)
    £227 all in for a new rack was pretty good going I think. But at a guess I’d say about the same again for it all to be fitted.
    Hope that helps.
  1. Steering Rack
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 15:59
  2. Steering rack help
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 19:10
  3. Steering Rack?!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 12:17
  4. Need a new steering rack :(
    By Xerath in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2010, 17:44
  5. Steering Rack
    By maxd cavy in forum Engine & Drivetrain
    Last Post: 26th June 2009, 09:21
