Thread: Limp mode when under load
    Flintshire
    Default Limp mode when under load
    Spanner light came on Saturday(150 CDTI) and into limp mode, fuel consumption through the roof, no fault codes read and reset by AA. Since then it as come on 3 times again but noticed that it happens if I accelerate over 3000 rpm or really load the engine. Goes out of limp mode after aprox 20 miles and light eventually goes out. Checked EGR valve on Sunday looks clean. Did two trips to the airport in it (200 miles) this morning and kept revs below 2500 and speed below 80 mph - no problems.( average 55 mpg)
    Any ideas guys?
    These things always seam to happen on Bank Holiday when the garage is shut!
    Regular Member addyboy1982's Avatar
    Northampton
    With my old DTI, it was the inlet hose that was loose - exactly the same symptoms as yours, under load and over 3000 revs. Re-fitting it more tightly fixed the problem.
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    yep this sounds like another vec hit with the same vault as mine check you cam pully is not loss on the crank ? check my imission threads out bud
    Regular Member Fruit'n'nut's Avatar
    Quote Originally Posted by topdogs View Post
    Any ideas guys?
    Mine (1.9, 150) occasionally does that at anywhere between 3,000-3,250rpm.
    Previously diagnosed (once) as split vacuum tube and replaced under warranty - on that occasion the light didn't go out when the car was re-started and it remained in limp mode until the replacement part was fitted.
    It has done it since but the dealer has been unable to diagnose any fault as no code was recorded by the car; the light goes out each time the car is re-started.
    I started a thread in "Troubleshooting" here last week and the answers I received indicated that a number of sensors could be at fault and should be checked. I've yet to book it in for this to be done (the car is two years old.)
    Would anybody be able to post up a pic with the inlet/vacuum tubes indicated please? Might help me self-diagnose any problems, rather than just tightening any jubilee clip I can reach
    Flintshire
    Thanks for replies will check the hoses later today and try and get it to the dealers Tuesday. Are the hoses easy to get at?
  1. Limp Mode
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 23:25
  2. eml & limp mode???
    By actionman in forum Engine & Drivetrain
    Last Post: 28th February 2011, 13:20
  3. Limp Mode
    By frenchman in forum Engine & Drivetrain
    Last Post: 25th October 2009, 21:35
  4. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  5. Limp Mode Help Please.
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 22:27
got up to 3000 revs under load and my vectra c went inti limp mode
