Results 1 to 10 of 11
Thread: car wouldn't start
    South London
    Default car wouldn't start
    Hi
    I just went to the hand car wash and when I started the car to drive away, it started and after a second or two stopped very abruptly. It wouldn't then start again. Turned the key and silence, not even the starter motor turnig.
    Got the lads to push me out of the way tried again ,still nothing. Thought, RAC but tried it one more time and bingo, all working again.
    The car is a 2.2DTi automatic. Any thoughts on what the problem is?
    I initially thought it was the automatic inhibitor switch but why did it stop so abruptly after it had fired?
    Your opinions will be apreciated.
    Jan 2008
    ipswich
    hi did you thought about going throw the gears like park reverse neutral and drive a couple times hope its ok johnboyna54
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine did it too, once. It's the immobiliser playing up a bit
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Was it a car wash that washes underneath the car? The water could have hit a switch or something??
    loughborough
    Quote Originally Posted by Celes View Post
    My immobilizer is playing up. what did you do to fix it?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I was only told it was the immobiliser, because the light with the spanner was flashing and the starter motor wouldn't budge.
    It did it only once and never again.
    loughborough
    Mine has the padlock picture on the display, and it says immobilizer fault on the screen in middle of dash.
    South London
    HI
    Thanks for your replies.
    Nol, I had no fault lights showing, the dashboard display was normal.
    May 2007
    Did you have this problem again? Or is it sorted?
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    i had this problem on mine when i first got it turned out to be the relays in the box next to the battery check them makes sure they are all pressed down properly
  1. car won't start :-(
    By michael_linford in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 19:31
  2. Were do i start
    By MCCABE in forum Engine & Drivetrain
    Last Post: 6th March 2011, 21:34
  3. 2.2 sri non start
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 13th February 2011, 00:44
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. 2.2 DTI will not start!!!!
    By Mark121 in forum Troubleshooting
    Last Post: 7th September 2010, 13:02
