Results 1 to 10 of 19
Thread: fh-80bt + steering controls not working + display
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default fh-80bt + steering controls not working + display
    Ok not long had my fh-80bt.
    Removed it this morning to secure the cage better, when i come to set it back up. The ****** steering controls will not work. I have followed the instructions several times to no avail.
    I have checked all the cables for damage. Anyone else had this problem?
    Using cables PC99-X45 & PC99-PIO.
    On a better note. I asked a while ago about how to make the time and date stay on screen when using an aftermarket stereo. Answer is to cut the red & white wire behind the display. I have one of the big displays. So dont know if this works for all.
    No i dont believe the solution for time and date has caused the problem with the steering controls.
    Nick
    Regular Member Bethan39's Avatar
    South Wales
    Have you got this sorted out yet mate i had a similar problem with mine recently it was the patch lead in the end it needs to be plugged together with the other adapter in a certain order if you still need help give me a shout
    Nottingham
    hey, still not sorted it, would love to know the order.
    Nick
    Nottingham
    also did u have to leave the buttons 20 minutes with stereo on or did they work instantly.
    South Wales
    Did yours come with instructions to plug the patch lead in a certain way on mine you plugged the patch lead into the adapter then plug the leads into the vx block connector turn on then off the ignition then plug in the jack lead and hey presto on some you need to do as above but tune in a radio station first to wake up the unit turn off the ignition then plug in the jack lead oh yes on mine it said never to connect the orange wires together may be different on yours hope this helps
    South Wales
    instant mate
    Nottingham
    mine came with a leaflet, said plug the 12 pio 12 pin in first, followed by the vehicle specific interface. then connect the iso's as normal and like you said.
    But the Piece of pper actually says PC99-SON on the top. they have crossed all the SON's of and written pio next to it
    South Wales
    so i take it it was working ok until you took it out to put the cage in better so it must still work you need to reinstall by unplugging the adapter and jack lead connect the patch lead into the pc99 then into main loom turn on and off the ignition then plug in the patch lead try that
    Nottingham
    tried the above about 8-9 times. Completely removed everything, reinstalled it all from scratch. There is nothin wrong with the rest of the stereo, its quite strange.
    South Wales
    i know what you mean i was the same everything worked but the steering wheel controls so can you confirm were the the steering wheels controls working fine before you took it back out or have they never worked let's start there
  1. Steering Wheel Controls Not Working
    By Cruize in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 10:40
  2. Steering controls/Display working once more
    By wotsthestory in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2010, 02:23
  3. steering controls not working
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2009, 20:27
  4. Steering controls and oem dash display HELP!!!!
    By turbo2.0 in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2008, 23:33
  5. Display & steering wheel controls
    By Stewart in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2006, 21:19
