Thread: No power until 2,500rpm
    Scotland
    Default No power until 2,500rpm
    Hi folks, hopefully someone will be able to shed some light on my problem. I have virtually no acceleration until the rev counter hits 2,500 rpm then the car drives fine. It is a 1.9 cdti 150. I have tried cleaning the EGR valve, but this made no difference. There are no fault codes showing either! Any ideas? Thanks in advance,
    Dave
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    try the boost sensor as well mate
    with the egr did you clean the intake on the engine side aswell?
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    Clean the EGR valve matey,it cured my problem
    EVERYWHERE
    Might also be the 'swirl valve' thingy.
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Default how to clean z19 egr valve (proper method)
    Did you clean both sides of the EGR Valve? The solenoid side seams to be the issue. You have to split the valve then you have to drill a 3mm hole in the black plastic cap and knock out with a punch then clean,greese and re-assemble. It has solved so many peoples problems I would try this next.
    There is a very good how to on it just search for "how to clean z19 egr valve (proper method)" .
    In fact here is the link. http://www.vectra-c.com/forum/showthread.php?t=45867
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Maybe someone's swapped your engine for my 1.8 petrol LS! Although that's got no power anywhere in the rev range!
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by keithsimmo View Post
    Once you remove the EGR valve gently push the spindle in the middle in. If it moves in smoothly and then release straight away without getting stuck then the solenoid is ok.
    If the inlet manifold is clogged up and or the link bar has come off, and the flaps are stuck in the wrong position this would have an effect on take off pull/speed
    Scotland
    Thumbs up
    I removed the EGR valve, again, and cleaned it, also used some WD40 on the soleniod \ plunger, also cleaned the boost sensor which was badly gummed up with oil and stuff.
    This cured the problem, but I suspect it was mainly the EGR valve, so at the weekend I will follow Keithsimmo's instructions and open the soleniod up to lub it properly.
    Thanks for the help ( especially the pic's on how to clean the soleniod \ plunger )
  1. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 6th June 2011, 18:55
  2. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  3. Replies: 11
    Last Post: 7th January 2010, 17:50
  4. Fault at 3,500rpm and resets itself?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 7th June 2009, 22:15
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
