Thread: Power Steering Fluid Top-up
    Gloucestershire
    Default Power Steering Fluid Top-up
    My power steering has been playing around for a few days now, sometimes it's just dead. Suspect I just need to check and top-up the fluid.
    Can anytone tell me what fluid to use? Halfords seem to do a GM6137M DII fluid for Vauxhalls - is this the right one, or is it for auto transmissions only?
    Also - I believe the tank is in the drivers wheel arch. Numpty question, but does the wheel need to come off first?. Any tips on accessing appreciated.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you need to use the green stuff, its called central hydraulic fluid (CHF)
    your pump sholud be under the drivers head light behind the bumper, so you will have to remove the bumper
    Gloucestershire
    Quote Originally Posted by glynn View Post
    Blinking bigger job then I expected . . . all to top up the fluid! CHF - sounds like something from Vx not something I can get today from Halfords!
    Quote Originally Posted by APJ View Post
    you will be able to get it from halfords, it will be about £11 for a ltr, should take about 30 mins to do the job,
    Full Member Big Sig's Avatar
    Think it can be done with a long funnel rather than remove the bumper to.
    the cap is quite tight up to the chassis leg
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    any pics of where it is as i want to top mine up but i cant be takin all the bumper of again
    Quote Originally Posted by big rich View Post
    its under the drivers head light, pull the splash sheild back and you will see it, but some are on the rack
    birmingham
    Engine : 3200
    cheers m8 i will have a look
    Gloucestershire
    Thansk for the info folks!
  1. Power steering fluid.........
    By Sway in forum Engine & Drivetrain
    Last Post: 18th December 2012, 20:06
  2. Power steering fluid
    By Friel in forum Troubleshooting
    Last Post: 6th August 2011, 23:29
  3. Power Steering Fluid
    By jrwilshire2003 in forum Troubleshooting
    Last Post: 23rd February 2010, 16:16
  4. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
  5. power steering fluid ??
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 17:14
vectra c power steering fluid top up
vauxhall vectra power steering fluid top-up
