Thread: Glovebox cable mystery!
    Paris
    Vehicle : Pre-facelift Vectra V6 3.0 CDTI
    Trim : SRI
    Engine : Y30DT
    confused Glovebox cable mystery!
    Hi All,
    Not sure if it comes as standard on all models, but the glovebox door / hatch on my pre-facelift SRi has an elastic cable type thing attached to it to stop it from dropping too fast when opened. I opened the glovebox today and with a lovely BANG the cable popped off and slipped into the void behind the dash.
    I've taken the entire glovebox out and had a good look around but I can't find the cable or where it's fixed to, I would have thought it would be attached right behind the glovebox or that there'd be some sort of reel mechanism but no joy so far.
    Any ideas? I've attached a couple of photos in case anyone knows off the top of their head! As far as I remember the cable threads through the rectangular opening on the right.
    Cheers,
    Hutch
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    sure it just was an error? ive never seen one of those.. sure its not the one for the light that just been stuck?
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Don't know about a cable. My glove box is softly damped to stop it crashing down with a thump.
    Paris
    Trim : SRI
    Engine : Y30DT
    @ kenp, thanks for the suggestion. It was a black cable attached directly to the glove box, none of the wiring cables behind the glove box are long enough to get caught or wrapped around.
    @ john, how is yours damped? The cable was effectively a damping mechanism, right now if I unlatch the glove box it just crashes down as far as the hinge will allow not the end of the world, but annoying nonetheless!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like you have a broken glove box that someone has made a temp fix.
    Regular Member darko2301's Avatar
    Croatia
    are you sure you had the cable?
    i know that i pushed my glove box too hard once as i wanted it to open faster and i heard something cracked ..
    when i took it out i noticed that there is some sort of shock absorber (black, made of plastic, barrel shaped, about 4inch long) which was doing the job and it broke..
    there was no cable
    Regular Member s0501291's Avatar
    Warrington
    Hi
    I fixed the damper on mine, I was a bit impatient one day and forced the glove box down and somthing went pop. Discovered that the piston inside the black cylinder/damper on the right side of the glove box, had come unclipped from the ram.. had to take the cylinder apart and re-clip the piston to the ram, pluss a little grease to make it easier,, works fine now
    Pete
    Engine : 2.2 Direct
    mine is damped lige the others.. only works when emty thou... as ive normaly have the car manual ect in there.. it just slams down.. (and its not broken) but if you have stuff in it.. you wont notice its damped...
    hull
    I had this happen to mine and now thanks to s0501291 im going to try fixing in one day lol.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I think the stretchy cable thing fitted to yours is a bit of a home made 'fix'. The damper on the back is a little weak. Mine's been broken for ages and ages and will stay broken, as I really can't be bothered repairing it as it doesn't affect usage,
  1. Key Fob Mystery
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 22:45
  2. mystery pic......
    By david.aka.judas in forum General Chat
    Last Post: 18th July 2010, 22:07
  3. Ipod cable in glovebox???
    By Darkmike in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2009, 21:27
  4. XBox 360 VGA cable and Advanced SCART cable FS
    By RSV_Ecosse in forum General items for sale
    Last Post: 2nd February 2007, 00:01
vectra c glovebox ram
