Results 1 to 3 of 3
Thread: Trouble changing gear
    Halifax
    Default Trouble changing gear
    Hello all,
    I have a 52 plate vectra C 2.0DSi
    Last week, my car suddenly gave difficulty changing gear, i.e. hard to get it in, but it goes if you pull hard on the stick.
    I took it to a dealer, but by then it had righted itself.
    Then yesterday it did it again. It is very hard to get in gear, but once in, all seems fine, i.e. I can put in 1st with a hard shove, then everythings ok, biting point good etc. If I pull out of gear, same problem.
    If I turn engine off, it goes in all gears with ease, press the cluth, start engine, agan, everything seems fine, until I pull it out of gear again.
    I put the handbrake on, and put car in 1st, then started the car, and then proceeded to 'rock' it a bit by moving the clutch pedal up/down for a bit, and now the problem has gone again.
    Nice man at garage says it's either, clutch has gone, or hydraulic assembly. Either way 5.5hrs labour to take box out and back on again is going to cost me over £400 just to see whats wrong with it.
    If it's then clutch plate, then £750, if its the assembly, then nearer £1000.
    Any ideas what it is, or is it worth doing anything (I want a new car)
    Regular Member barkzz's Avatar
    Get the gear linkage checked firstly,
    I had this with my 2nd hand SRI bought from Network q.
    They adjusted this, and its been fine since.
    When it was wrong i couldnt get first gear, without going to another gear first, then keeping the foot on the clutch, go back to 1st.
    Quote Originally Posted by jwturpin View Post
    Hello all,
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like the linkage, as it has 2 cables, if not then it could well be the clutch
  1. Top gear in trouble again
    By new boy in forum The 'Off Topic' room
    Last Post: 14th January 2012, 01:58
  2. Top Gear in trouble again!!!!!!!
    By bigboynigs in forum General Chat
    Last Post: 5th August 2011, 13:07
  3. trouble getting in gear
    By markocarlo in forum Engine & Drivetrain
    Last Post: 19th January 2011, 18:52
  4. Trouble changing fuel filter
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 18:16
  5. Top Gear Team in Trouble (again)
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 4th July 2008, 23:08
