Results 1 to 10 of 27
Thread: VXR GearKnob
    Full Member spennny's Avatar
    Blantyre
    Default VXR GearKnob
    Where is the how to fit
    Regular Member darko2301's Avatar
    Croatia
    erm at your dealers?
    do you have just the knob (the part which you hold) or complete system with those 2 wires and screws etc?
    Blantyre
    This Bit
    Croatia
    well, you could remove the trim and then undo 4 screws found at the bottom.. i wouldn't touch those 2 cables or disconnect them but just pull the knob with the rest out if possible and then figure out how to dismantle it lol, it surely isn't a job i'd like to do myself..
    usually they sell complete because as i see you will have to connect that metal part to something which will change gears, looks complicated to me..
    this is what i thought u have:
    Blantyre
    Croatia
    is that because of what you have or because of what i've posted?
    I changed a complete Knob on a 'B' that was rod type fittings I think. Marked the connections with tipex undid the whole thing & replaced like for like. Why not pop over here & ask a couple of the very knowledgeable guys for help .............
    Not having looked at the 'C' bit's yet this was how I did the 'B' hth ....
    1. Pull up the gear lever gaiter, unclip the metal ring at the bottom of the gear lever and pop out the pin. Lift out gear lever, replace with new and replace pin -- total time about 30 seconds!
    Blantyre
    Quote Originally Posted by darko2301 View Post
    What you've posted
    Croatia
    mate it would be the best as tadpole said, do a little trip to him if he isn't far and if you have time as two brains are smarter than one and you don't want to mess something so...
    Regular Member silverhairedracer's Avatar
    ESSEX
    Quote Originally Posted by spennny View Post
    Do you want to sell the "old "gear knob ? if thats a six speed my friend is after one .
  1. New gearknob
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2010, 17:06
  2. vxr gearknob
    By tankman in forum Styling
    Last Post: 19th February 2009, 22:39
  3. Different gearknob..
    By ROY2593 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2008, 16:31
