View Poll Results: what valves would you have
Voters
32. You may not vote on this poll
  • metal
    16 50.00%
  • rubber
    16 50.00%
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: what valves woul you have
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Default what valves woul you have
    as above,
    metal
    rubber
    cheers
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    metal can be a beyatch to remove if not coppaslip'd up, i found that out the other day!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Rubber 'go cart' valves,only 1/2 long, so nice and neat.
    Quote Originally Posted by tyreman View Post
    but they might be to short to get a tyre pressure gage on them
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    It's best to get one and check but they were fine on my team dynamic wheels,just depends on the position and depth of the valve hole.
    just found these http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230343948906 and i have irmscher wheels the same as ditchp
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    At that price i'd buy and try 'em,try measuring your existing valve and see how it would be only 1/2 long that would give you an idea.
    is that an overall length of the valve ??
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    That's the length from the base of the valve hole (face side),hence if the casting is very deep you'll end up with just the tip of the cap showing!,this site might help,http://www.tyre-rite.co.uk/searchres...?CategoryID=43.
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    just make sure they aren't too fat. some older wheels require large diamiter base valves. Meaning the hole in the wheel for the valve is larger than normal. Those particular ones look ok though.
    Rubber valves all the way. The valve seals itself. if you start mucking around with bolt in valves you may in the future start having issues with air leaks
    Rubbin'z racing Harry!
  1. Egr valves
    By mon in forum Engine & Drivetrain
    Last Post: 9th November 2012, 21:34
  2. Are the EGR valves the same?
    By amir2300 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 22:05
  3. what woul you do with 30000 pounds?
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 16:38
  4. EGR Valves
    By VectraGezza2010 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2010, 19:59
  5. air valves?
    By WKD-mcc in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2009, 18:36
