Thread: Boost sensor didn't sort it...
    Over the hill and far away...
    Default Boost sensor didn't sort it...
    ...after cleaning it.
    I've been having a problem where the cooling fan light, and the spanner light comes on. When it does this the engine sounds somewhat harsh, and at idle hunts badly between 100-1000 rpm (like, vroooom...vrooom...vrooom, constant revving sort of thing)
    To replicate this problem, all you have to do is unplug the wiring loom that has the boost sensor & oil temp sensor on it (unplug the entire loom) and try to start it...it will do the same.
    I have cleaned up the boost sensor, which was very mucky. However the problem has just started again.
    What I want to know is, what else is run from that loom, as obviously it is something on there.
    EDIT :: It's a 2001 2.0 DTi
    EVERYWHERE
    Have you also posted this in the 'Engine & Drivetrain' section ?
    Full Member Big Sig's Avatar
    Or checked that the fans work as they should?
    D_D : No I haven't. I thought the diesel section would be most appropriate? Should I post there too?
    B_S : Yup.
    When these "episodes" happen, i lose the rev counter also.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If its doing it on idle sounds like it could be the air flow meter at fault. Probably best to get someone to read the codes for you
  1. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  2. Boost sensor
    Last Post: 16th September 2010, 14:09
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
