Thread: oil addative
    glasgow
    Default oil addative
    hi
    just had full service done and have had engine flushed what is the best addative to use in the oil for smother running a mate has recommended wynns performance i know there is a lot out there but which is best for vectra cdti 150 1.9d
    Mileage : 000
    I can not recomend any. I used to use them on " older" cars in the past.
    But what I will say, is that Vauxhall do not recomend any, as they sat that they may undermine the oil. Bu no doubt other members will have their opinion about this.
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    i always sling some cam lifter stuff in there if im using cheaper oil and it gets rid of the diesel "Clatter". but i only use magnatec now and Slick50.
    id allways recomend Slick50 allways makes mine (2.0DTi) sound a little bit smoother.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I would say don't use any unless you need to.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I'm sure it even mentions in Tis that adaptive can void your warranty as it then doesn't conform to Vx spec.
    Regular Member xrken's Avatar
    northampton
    rolleyes
    there is only one iv used it for years and its slick 50
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Internal lab and engine test bench investigation revealed that the usage of not released oil additives will cause
    an increased engine oil consumption. In some cases the measured oil consumption has increased by 100%.
    Modern Opel engines in combination with high quality engine oil do not need additives. Therefore the
    usage of any not Opel released engine oil additive is disapproved. All related warranty claims will
    be rejected.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    DO NOT USE ADDITIVES, they do nothing but harm and cost you money. Why is Slick 50 in complex legal wranglings?
    I posted a report on here a while ago from independant research proving they weren't beneficial
  1. Auto gearbox addative
    By llanddewi in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2010, 22:12
  2. Oil Addative
    By MattW in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 20:28
