Results 1 to 10 of 11
Thread: Fitting an EGR valve to a 150cdti
    Regular Member robk6112's Avatar
    Halifax
    Default Fitting an EGR valve to a 150cdti
    Hiya
    Is there a how2 to on here for this?
    Regular Member Craig1985's Avatar
    harwich essex
    its really easy only a few bolts and few Torx bolts and 2 gaskets, and probs PM me and ill do my best to help OR you asking before you make a HOW ? lol
    Mileage : 000
    Is this any help. It is more how to clean the egr valve.
    Halifax
    Yeah this looks easy- even I might manage this!
    Halifax
    Thanks guys
    Mileage : 000
    Halifax
    This job is now complete and the car is running great but now when I turn it on there is a car with a spanner light on. Any reason?
    Regular Member denzo's Avatar
    Runcorn
    I think the Engine Management System may need to be reloaded following replacement of the EGR?
    harwich essex
    Quote Originally Posted by robk6112 View Post
    removed mine loads of time not a problem?
    all connectors/plugs pluged together properly?
    gasket sealed properly? i would recommend new gaskets each time? only £2-£3
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    Did you turn the ignition on with the EGR removed?, if you did, this would cause it.
    Is the plug properly pushed right up into place on the EGR, thought mine was but it wasnt. This would cause it too.
  1. Fitting a new EGR valve
    By justin32 in forum Engine & Drivetrain
    Last Post: 14th November 2012, 13:22
  2. Fitting a dump valve like it or not !!
    By nath-lav in forum Diesel Engine related
    Last Post: 19th February 2012, 10:50
  3. adjusting valve clearance 150cdti
    By hairy31 in forum Engine & Drivetrain
    Last Post: 12th January 2011, 20:08
  4. fitting a dump valve
    By jb-redbull in forum Petrol Engine related
    Last Post: 27th August 2008, 12:52
