Likes Likes:  1
Thread: Trolley jacking points & Axle stand locations?
    Regular Member Craig1985's Avatar
    harwich essex
    Default Trolley jacking points & Axle stand locations?
    As above, where do you jack your car up?
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by Craig1985 View Post
    I changed both rear tyres last weekend & used a trolley jack with a block of wood cut to size to fit the rectangular jacking point boxes (plastic!) in which the ordinary accessory jack fits. I was therefore jacking up directly under the wooden block which was in the normal jack locating box. Because the box is plastic, don't try & jack up directly under it using the jack.
    Had I been using axle stands though for a bigger job, I'm not sure where I could have put them though.
    If you search the forum using 'jack' or 'jacking', then there are quite a few threads about jacking up.
    HTH
    harwich essex
    Quote Originally Posted by Pete B View Post
    HTH
    ha thats what i done last time but didnt know if it was ok like that?
    Regular Member old cruiser's Avatar
    slough
    I think we could do with some pucker photos from some experts as to where to put the axle stands etc. only ever had this issue on the vectra I have to say and last time I jacked it up, I too made some wooden blocks to fit where the normal car jack goes.
    Cheers Pete
  5. Likes artvec liked this post
  1. Trolley jack and axle stand placement
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2012, 00:20
  2. axle stand points
    By djlee in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 02:42
  3. front axle stand points
    By Grimo72 in forum General Chat
    Last Post: 14th May 2010, 02:49
  4. Front jacking points, and using axle stands
    By PeterVV in forum General Chat
    Last Post: 6th May 2010, 12:09
  5. Jacking/axle stand help
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 10:09
vectra c jacking points
vectra c axle stand points
jack up and axle stand signum
vauxhall vectra c jacking points
axle stand points on a Vauxhall Zafira
best place axial stand vectra c
vauxhall insignia jacking points
where to place axle stands vectra c
trolley jack points vauxhall
jacking up points in Vauxhall Vectra
vectra c rear axle stand position
vectra c plastic jack point
where to put axle stands vectra c
vectra axel stand position
jacking up.a vectra c
vauxhallsignum jacking and axle stand points
jacking up vectra c
vectra c jacking point pad
