Results 1 to 3 of 3
Thread: noob questions:
    lincoln
    Default noob questions:
    Hi there,
    I have just picked up a new 04 Vectra and want to install a Sony MEX-BT2600. After going around in circles I think I have a list of what I need:
    1 x FP-19-00 Facia Panel Adaptor
    1 x PC5-27 Aerial Antenna Adaptor
    1 x PC5-110 Stereo removal key
    1 x PC99-X06 Steering Wheel Interface
    + sony patch lead?
    Will the facia plate include the cage? It is difficult to tell from the descriptions?
    Is this everything I need?
    Also, can any one recomment some speakers that can be a drop in replacement for the existing ones which are not great.
    thanks people
    andy
    Apr 2009
    Anglesey
    The fascia will clip in place once you remove the original radio & cage. You then insert the cage from your replacement and slide in your new unit.
    I found the following speakers as a direct replacement but they are a bit pricey. You could just buy the autoleads speaker adapter and use almost any 17cm component speaker.
    http://www.caraudiodirect.co.uk/pion...477u7n3grdcgn5
    The list of parts looks fine to me but i'm not sure about the steering interface as I got the one for the facelift vectra. On the autoleads site you can download the spreadsheet showing all the correct parts for your car. With the fascia make sure you get the right colour, I got the gunmetal version which was the closest match I could find.
    I can recommend the following ebay store for the bits, they were cheap and gave good service:
    http://stores.shop.ebay.co.uk/Dynami...__W0QQ_armrsZ1
    Good luck, hope it all goes well for you.
    ben
    lincoln
    thanks for the help, have finally got it all installed.. the biggest surprise was that with a decent header unit the default speakers aren't all that bad after all
  1. Noob!
    By JM53 BEL in forum Introduce yourself.
    Last Post: 6th October 2012, 11:55
  2. another noob...
    By shadoweyes in forum Introduce yourself.
    Last Post: 23rd June 2012, 19:31
  3. Noob car pics, & a few questions !!!
    By thefibreguy in forum Styling
    Last Post: 19th May 2010, 17:40
  4. Ditching CDR 2005 - Noob questions
    By AirCooledHeaven in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2007, 21:18
  5. Just a couple of questions from a Vec noob
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2006, 19:31
