Thread: Cruise Control problem fixed by lifting stalk
    Regular Member KevinG's Avatar
    South Bucks
    Talking Cruise Control problem fixed by lifting stalk
    Hi
    Been having problems with my cruise control over the past few months, it would only allow me to turn it on once or twice on a journey, then when i turned the ingition on then started again i would get another 2 goes. Well today it turned on then turned off again after about 30 seconds
    Got to work and searched on here and stumbled across a thread which said to slighly lift the stick when turning it on, didnt take a lot of notice who wrote the thread as i thought it cant be that easy. Well on my way home tonight i tried it, it worked , i must have turned it on about 15 times and it stayed on. Wish i had taken a note of the original thread as i cant find it now, if anyone has seen it please let me know so i can thank them.
    So if you are having problems with cc, slightly lift (very slighlty) the stalk and turn it on.
    Hope this helps others.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Nice one mate, not seen that one before. The most common one is to lift the clutch peddle with your foot ans the spring sags.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by KevinG View Post
    Hi
    Your problem is ongoing with my 3.2V6 auto. Does lifting the stalk slightly activate the indicators though?
    South Bucks
    Rushy, mines auto mate,
    gtr1000, no you dont need to lift it that much, really its so light you cant beleive it works, same here v6 3.2 auto
    give it a go
    Regular Member formby's Avatar
    paisley
    Yes I've finally managed to help someone else after all the help and advice I have been given on this site
    the original thread is below
    http://www.vectra-c.com/forum/showthread.php?t=80951
    I found this out by coincidence, and it is still working fine, but do you have the same problem I have with the right turn indicator having a mind of its own at times and switching off just as you go to turn right?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by formby View Post
    ... do you have the same problem I have with the right turn indicator having a mind of its own at times and switching off just as you go to turn right?
    Mine does that too, there is one mini roundabout that I use every morning and without fail I'll be indicating approaching it, but just as I go to turn the indicator turns off - there is absolutley no turning the left either, not even slightly.
    Very odd, I just press it again half way round
    South Bucks
    Thanks Formby,
  1. Cruise control stalk
    By chrisvectra in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2013, 01:15
  2. cruise control fault, new stalk fix problem?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2013, 11:16
  3. Cruise Control Stalk
    Last Post: 27th April 2011, 12:51
  4. cruise control stalk
    By n8sby in forum Parts for sale
    Last Post: 25th May 2010, 11:48
  5. cruise control stalk
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 16:14
