Thread: Diesel, 1.9 - rev ceiling?
    Regular Member Fruit'n'nut's Avatar
    rolleyes Diesel, 1.9 - rev ceiling?
    http://www.vectra-c.com/forum/showthread.php?t=82372
    Concerning the 1.9 cdti 150 ...
    In particular, Maverick's post:
    Quote Originally Posted by Maverick View Post
    If the car you were revving was not up to full working temperature, it won't rev much above 3700rpm, it's a safety parameter built in.
    When up to running temperature they rev to just over 5000rpm.
    How long should this car take to get up to temperature?
    If the car is running at the right temperature, then what might be the most common causes of the engine not revving as high as it perhaps should?
    Mine sometimes shows a fault light and goes into limp mode if revved over 3,000 rpm in the higher gears, even when thoroughly warm. However, the fault goes away when the ignition is switched off and on again, and doesn't ever seem to be recorded for the Vx dealership to diagnose.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    that sounds like a sensor somewhere mate, its not right anyway
    Mine's takes about 5 minutes or so of 2000rpm driving to get up to temperature depending on the OAT itself - during the winter I can get it to drop off the scale when driving around town...
    Thumbs up
    Quote Originally Posted by Grimo72 View Post
    That ^ had crossed my mind too.
    Thank you
    I can feel a fourth "warranty" visit to the dealership coming on
    Quote Originally Posted by Penfold101 View Post
    Mine too, it's usually up to the 85-c mark within a few minutes of normal driving.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Ceiling Spot Lights x 8
    By Vaux-Man-G in forum General items for sale
    Last Post: 29th May 2009, 17:15
  3. Hall ceiling has come through :(
    By Gregg in forum The 'Off Topic' room
    Last Post: 1st May 2009, 23:10
  4. This is a ceiling mural in a smoker's lounge.
    By glynn in forum Comedy & Humour
    Last Post: 20th April 2009, 22:03
  5. Advice on sagging ceiling + loft insulation
    By danlat1415 in forum General Chat
    Last Post: 1st March 2009, 00:17
