Results 1 to 10 of 24
Thread: retro fit fog lights on a facelift
    lemvig
    Default retro fit fog lights on a facelift
    Hi.. can anyone help me with this.
    I did read the how 2s on the retro fitting but thats on a before facelift.
    the first problem I do have is that I cant find any surrounding to attach my fog lights to on the inside of my front bumper.
    Do I have the wrong lights or is it possible to buy the surrounding part ?!
    a parts number would be great ?!
    I did buy the lights from this ebay seller because he wrote its the originals.
    Iva posted a pic of my lights and a pic from a fitted fog lights and they a just not the same on the back.
    http://cgi.ebay.de/Opel-Vectra-C-ab-Bj-08-2005-Nebelscheinwerfer-ORIGINAL_W0QQitemZ230341033405QQcmdZViewItemQQptZA utoteile_Zubeh%C3%B6r?hash=item230341033405&_trksi d=p3286.c0.m14&_trkparms=72%3A1229%7C66%3A2%7C65%3 A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C29 4%3A50
    the next question is, how much do I need in parts to retro fit them ?!
    my car do has the plugs to the fog lights behind the fog lights grill. Ive posted a pic that shows the blue plugs. Its them with the red V. (Id borrowed the pic from a how 2s on chrome rings).
    Will I still need a wiring harness kit and a relay. ?!
    can I use a original switch for fog lights or should I buy a on/off switch
    sorry that my english is not better
    Sunny Dartmoor
    I think its just plug and play with the facelifts m8,and you need to buy the grille's so the foglights sit properly,i'm sure someone has done this hope that helps you out,good luck
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    andy.l have probaly done it to some cars.. but if wirng in place probaly just a new switch and tech2 (and relay, fuse)
    lemvig
    Hi and thanks. I do have this switch and I do have the the grills but I do still need help with how I can screw my fog lights on to the backside of the frontbumper or if Im missing a surrounding part.
    please look at the link above so you can see what fog lights I have.
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    those round front foglamps you have bought as the link of ebay are more for a vxr front
    bumper which they mount onto the back of the vxr fog grilles,you need the foglamps as
    in pic 2 and the relevant grilles.
    you need the ones from either and sri facelift or signum design as
    there the same foglamps for both models
    as fir the switch then just replace your existing 1 and fityour new 1 and
    when youve sorted the foglamp issue out connect it all back up and then
    you will need a tech2 programming for them to work.
    Engine : 2.2 Direct
    Hi mate ive gotten your PM
    do you have the sourrond for the foglights.. ?
    (danish -> har du det som skal være rundt om tågelygterne)
    you need to see if you can get the correct foglights! i couldnt find any on ebay.co.uk
    (danish -> du skal se om du kan finde de korrekte tågelygter, der er ikke efter hvad jeg kunne se nogle på ebay.co.uk)
    If you cant find any i can help finding the correct part nr. for them.
    (danish -> hvis du ikke kan finde nogle kan jeg finde et korrekte reservedels nr. på dem)
    Engine : 2.2 Direct
    i could only find one side on ebay.de
    http://cgi.ebay.de/Nebelscheinwerfer...3A1%7C294%3A50
    Quote Originally Posted by kenp View Post
    There are a few listed on ebaby.co.uk Ken hth ...........
    Engine : 2.2 Direct
    not that i could identyfi for facelift for sure
    Any good at a price, more than one available hth ............
    link
    link
  1. retro fit fog lights???
    By mick 1986 in forum Styling
    Last Post: 22nd April 2015, 17:50
  2. Retro fit xenon fog lights
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2009, 01:05
  3. Retro-fitting pre-facelift passenger door switch to facelift
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 15:58
are face lift vectra any good
