Thread: Coilovers question....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Coilovers question....
    does anybody know if you can just buy the coilovers for the rear of the vec? if so any links or rough price.cheers
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    dont think you can, also why, why not go for a full set.
    on ebay theres some hottunning coilovers for £400,
    i used them on my old vec b and they were that good im havin em on the c
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    coilovers on the rear of the vec are pretty much the same as a standard suspension setup, in that, the shock and spring are seperate. the only difference is that the spring has an adjustable height platform, and are abit shorter.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by carl bear View Post
    i need the car to be sat lower at the rear, happy with how its sat at the front, can you recommend any for the rear?
    Full Member Big Sig's Avatar
    Will having the front/rear at different heights effect the abs at all? (just an honest question )
    im not aware of anywhere where u can buy just rear coilovers. you can get custom springs made, but again im not sure where.
    i use KW coilovers on my vec and ive used FK coilovers on other cars. had no problems from either.
    having the car sat at different heights wont affect the abs, it may affect the handlin due to the stiffness of the springs bein set up for different ride heights (hope that makes sense).
    Regular Member SRimonkey's Avatar
    wednesfield
    Quote Originally Posted by bobby-tupper View Post
    fat rear passengers?
    Ok thanks, I thought it did due to the brake bias set up. Learn something new everyday
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    cheers mate
    as for being sat at different heights...... its not sat level now and the brakes work fine,they were checked out on the rollers at my mates garage after we did the brake pipes last weekend.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    anybody else know if i can just get the rears?
  1. Coilovers! Jom? FK?
    By Couttsy in forum Suspension, Wheels & Brakes
    Last Post: 5th November 2012, 21:01
  2. Question for those who have coilovers
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2012, 22:27
  3. Kw coilovers possible question for spoons
    By pipamish in forum Handling & Braking
    Last Post: 10th May 2012, 22:08
  4. Coilovers
    By spooney in forum Handling & Braking
    Last Post: 30th October 2009, 12:16
  5. Coilovers
    By rob888 in forum Handling & Braking
    Last Post: 26th January 2008, 13:00
