Results 1 to 10 of 20
Thread: Headlight allignment?
    Newcastle under Lyme
    Question Headlight allignment?
    Can anyone tell me what the headlight height needs to be set at. I know this is probably more technical than I am planning but if I hold a pole in front of the car with the lights on how far in front of the car should I hold it and how high up the pole should the top of the light hit?
    Also Ive found the allen key hole which raises the lights but there is another right next to it which doesnt affect the height of the beam
    [Ex]Admin Duncan's Avatar
    The other allen key adjust the beam left to right. As for trying to align them correctly, you really need to get it onto the gizmo that they have an MOT station. Anything you try and do yourself is only going to be approximate.
    approximate would be good/better than it is at the moment lighting the 3 metres in front of the car. Does a headlight allignment for £18 sound right? Seemed excessive to me considering no parts are needed
    Regular Member gaz4d's Avatar
    Glasgow
    If you google "headlight alignment", various sites are suggesting circa £5 - £10.
    thats more like the price I was thinking. Anyone fancy being kind and stepping outside and measuring 1 metre in front of the light while on what the light goes up to?
    Will I have to have them alligned everytime I take my lights out?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Go to a local MOT place, bung em £10 to use their machine for max 10 minutes and adjust them there and then
    adjusted earlier so the lamps point about 30 degress higher than prev and took it for a drive and I can now see the road again at night.prob not right but at least I can see again
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    id go to a mot test center and just ask them to adjust them or wait til your next mot and do them then
    Mot isnt due for 2 years, Been quoted £14+vat so its getting cheaper but still not happy paying that much for a 5 min job
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The easy and approx way to do it is to park over looking a car park, and relatively flat. (but is approx, should be OK though)
    Cover one of the lights with a thick coat (or otherwise block it's light beam)
    Adjust the height switch to pos 2 on the dial and then using the allen screw adjusters set the range of the top of the beam to a reasonable distance and slightly left of centre. Repeat for the other light and just make sure that the offside light is adjusted more left and slightly lower then near side.
    Should really only take 5 minutes and will give you a surprisingly good result.
    If you then get flashed a lot or put weight in the boot, you can always adjust them down with the dial switch.
  1. 4 wheel allignment
    By pompey-pimp in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2012, 11:53
  2. trackace diy wheel allignment
    By Al 22 dti in forum The 'Off Topic' room
    Last Post: 9th June 2011, 21:55
  3. Vectra C SRI Wheel Allignment
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 12:26
  4. New NCTs and allignment done
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 18:56
  5. Post lowering allignment
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 12:44
trackace 1.7 mm to degrees
