Thread: Washer Problem AGAIN
    North Wales
    Default Washer Problem AGAIN
    Hi
    About 3 months ago i had a problem with my washers.
    They werent "squirting" water i could here the pump running but no water coming out of jets.
    I took to my local Vaux as i still had warranty. They told me that the filter in the pump was blocked.
    Now i have exactly the same problem. Just wondering if any one else has had this problem.
    And is there a How 2 on it...
    Thankz Folks
    May 2006
    scotland
    Try steradent in the water bottle. There are threads on here discussing this.
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    mine did the same,i took the bottle out and gave it a good clean and fitted a new filter,has not done it since
    North Wales
    were is the filter ? is it in the actuall bottle or is it an in-line pump ?
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    Quote Originally Posted by craig-k View Post
    the filter is at the bottom of the bottle and is also the seal for the pump,when you pull the pump out you will see a black rubber thing left in the hole,that is the filter/seal
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    i had this problem and traced it back to the one way valves that are located on the elbows that are attached to the pump , inside you will see a spring and a little ball in there, i prised the spring out and the ball then reatched them and put new one way valves in further up the pipe, got the parts from halford for a few pound and has worked like new since , if the filter is clean like mine then check the elbows mate, just need to take inner arch off to get to the water bottle and pump
  1. pressure washer problem
    By MACVVT in forum Detailing and Car Care Discussion
    Last Post: 2nd July 2012, 22:07
  2. wiper and washer problem
    By Roberto1981 in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2012, 20:26
  3. Help please with washer jet problem!
    By waynec22 in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2011, 09:35
  4. headlight washer problem
    By ditchp in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2010, 22:06
  5. window washer problem
    By patrick1062 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2008, 17:47
