Thread: pcd xoffset xbore x fittings = lost !!
    WGAF#5
    Default pcd xoffset xbore x fittings = lost !!
    guys the signum has the following
    pcd 5x110
    offset 35-45
    bore 65.1
    my question is on the following three options would they fit or not ??
    as there not the usual manufacturers we look at........ might try something different but it depends on if it works or not....
    5x108 35-45 63.4
    5x108 38-45 65.1
    5x108 38-52 63.4
    thanks in advance
    Dez
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    middle will fit with wobbly bolts, the other 2 will need centre bored out and wobbly bolts.
    [Ex]Admin Duncan's Avatar
    As the middle one is the same bore then that will mean you don't have to do any machining, although as they are all 108 PCD then it means you'll need to use wobbly bolts. You wouldn't want to use the last one, even if the bore was machined, if it was 52 offset. Too much of a difference.
    EDIT: Carl sneaked past the post before me! lol
    WGAF#5
    cheers guys i knew i could rely on you .......
    so these would fit = maybe refinished in black
  1. ISOFIX Fittings
    By Chris SRi in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2011, 09:08
  2. fog lights fittings
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2010, 02:25
  3. Sideskirts fittings
    By 3.2wales in forum General Chat
    Last Post: 25th October 2010, 21:06
  4. Fittings
    By brant2474 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2008, 13:14
  5. sidelight fittings
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 10:02
