Thread: Oil catch tank
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Question Oil catch tank
    anyone got any pics thinking in doing this oil catch tank mod please
    Newcastle under Lyme
    Some one was selling one a while ago and had a pic fitted. ill see if I can find it
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    What does it do exactly for your car?
    And is there any benifits?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is this the device that stores pressurised oil during normal engine running and then pre-pressurises the engine oil system before you next start it?
    no I was told it gathers condensation which is given off from the oil when hot. Was told it wasnt worth while on my 1.8 petrol only high end ones. no idea why
    Quote Originally Posted by Sean-2.2Direct View Post
    It basically stops the oily vapour that gets vented out from then being fed back into the inlet. Also, on a turbo car it stops oil vapour being fed into the compressor side of the turbo and into the intercooler, which can reduce the efficiency of the intercooler if too much builds up over time.
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    so would this also benifit turbo diesels.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Works very well on the 2.2 Sean. Normally the oil vapor is feed into the intake via the little pipe from the cam cover to the intake pipe just after the MAF. As you know our TB's get covered is oily deposits, most of this is from the cam vent. The catch tank goes in between the Cam outlet/vent and the intake. The catch tank will "catch" any liquid oil and stop it going through the intake system. Its not really wise to have it vent onto the atmosphere like in the pic. Instead of the Filter, you should really have another pipe going back to the intake. This way any vapor is burned off, the intake vac will also help draw the vapor through.
    VENT PIPE
    INTAKE
    CAM BREATHER
    You don't just put the tank in between, you mount the tank on the inner wing and obviously extend the pipework. HTH
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Quote Originally Posted by Darryl2.2DTI View Post
    im interested in this
  1. oil catch tank.
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 00:32
  2. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  3. Oil catch tank
    Last Post: 23rd December 2011, 16:04
  4. oil catch tank
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 00:25
  5. oil catch tank
    By spidermonkey in forum Engine & Drivetrain
    Last Post: 16th August 2011, 14:40
