The power that goes to the glove box light, could dis connect it and use it as a power supply, and whats perm / neg
Cheers
Cheers
Not sure on what you want to power from it? It only supply a certain amount of current before the IPEC (interior electronics module) goes nuts and start to shut down! It would be black as Live/Positive and Brown as Negative
I thought about that for a permanent live supply for the memory in my aftermarket radio
but the power to the light cuts out after a few minutes when the ignition is switched off
so it was no good for the radio. The wiring colours are, single brown and blue coloured wire supply and the brown wire is earth.
What about the fag lighter?
i would say the VDA plug next to the glovebox if present.. but Fag lighter and VDA plug is max on 10 amp..
Cut the wire to the fag lighter not corners. Is this for the sunvisor screen?
How much does a media center draw in current?
