Results 1 to 10 of 17
Thread: Glove Box Light
    Full Member spennny's Avatar
    Blantyre
    Default Glove Box Light
    The power that goes to the glove box light, could dis connect it and use it as a power supply, and whats perm / neg
    Admin plasma's Avatar
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    Not sure on what you want to power from it? It only supply a certain amount of current before the IPEC (interior electronics module) goes nuts and start to shut down! It would be black as Live/Positive and Brown as Negative
    Blantyre
    Quote Originally Posted by plasma View Post
    Ok thanks Plasma,
    I thought about that for a permanent live supply for the memory in my aftermarket radio
    but the power to the light cuts out after a few minutes when the ignition is switched off
    so it was no good for the radio. The wiring colours are, single brown and blue coloured wire supply and the brown wire is earth.
    Surrey
    What about the fag lighter?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    i would say the VDA plug next to the glovebox if present.. but Fag lighter and VDA plug is max on 10 amp..
    Blantyre
    Quote Originally Posted by steve1975l View Post
    Its fine, will just use the fag lighter, was just trying to cut corners
    Surrey
    Cut the wire to the fag lighter not corners. Is this for the sunvisor screen?
    Blantyre
    No mate, my media player thats going into the glove box
    Or could i wire it into the fuse box thats on the internal lhs of the cat ??
    Surrey
    How much does a media center draw in current?
  1. Glove box
    By Garfo in forum Styling
    Last Post: 30th June 2011, 23:02
  2. Glove box
    By tubby in forum Bodywork & Interior
    Last Post: 17th May 2011, 21:13
  3. glove box light
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 13:16
  4. Glove Box
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2005, 00:05
insignia glove box light
vectra c glove box light
