Thread: Disable Alarm On 05 Vectra.
    Lymington
    Default Disable Alarm On 05 Vectra.
    Hi Guys.
    Does anyone know how to lock the Vectra without setting the alarm?
    I thought that if you opened the windows using the remote that would automatically disable the alarm, but this does not work... it goes off... Poor dog ;-)
    Thanks!!!!
    Regular Member andymcniven's Avatar
    newcastle upon tyne
    press the switch to the right of the radio that looks like a little man rumming then lock car that disables the internal sensors for when you leave dog in with windows open etc
    11 Post(s)
    Yep, as andy says, you can either disable the internal sensors, but the alarm will still be set, or if you don't want the alarm set at all, reach in through another door, press the lock button on the drivers door (that's the one by the windows, btw, not the door pin) and exit out the door you reached in through.
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Dave, what difference does it make pressing the central locking button as opposed to pushing down the door pin? If I reach in and depress the pin, all the doors lock, much the same as having pressed the central locking button, and I can then just exit the car.
    Only reason I ask is that I can easily open the driver's side rear door and reach the door pin, but I can't reach the central locking switch without going away round to the other side of the car!
    11 Post(s)
    Puppet,
    on Vectra-C's from around 2005 (or slightly earlier/later) the central locking system changed. Pressing down the door pin on the drivers door only locks the drivers door. Same as if you lift it up when all the other doors are locked.
    Says somewhere in the handbook that to lock all the doors you have to press the lock button on the elecy window/mirror panel.
    You're probably one of the luckier ones who have a slightly older Vec-C that the central locking can still be operated by pressing or lifting the door pins.
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Thanks for the explanation.
    My Vectra is an early C Model (2002) so what you are saying makes sense. Sounds like I can just happily reach in the back door if need be.
    11 Post(s)
    I found another way today. Open the drivers window. Reach in and press the lock button (or lock pin if the C/L operates from that). Then press the close window button and remove your arm before it gets trapped as the window goes up.
    IMPORTANT Remember to remove your keys from the inside of the car first.
  1. Give up how do u disable a vectra c alarm
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2017, 10:10
  2. vectra parking sensors disable
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 18:00
  3. Disable alarm?
    By TimK in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2012, 00:33
  4. Vectra C SRI Alarm
    By 150_SRI in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 22:52
  5. Vectra C Alarm
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2009, 23:19
how to disconnect alarm on vectra c
how to disable car alarm with dog in car Vauxhall Vectra
vectra alarm dog in car
how to turn off vauxhall vectra alarm
how to disable the alarm on my vectra
how do i turn off my alarm vectra c
car alarm in vectra
alarm na promie vectra c
opel vectra c factory alarm bypass
where r the vectra alarm sensors
vectra car alarm
vauxhall insignia disable alarm
how to turn off a car alarm on a vauhxhall vectra
vectra c 3.2 v6 alarm removal
disconnect alarm vauxhall vectra
how to disable alarm on vauxhall vectra when dog in car
how to disable alarm from 2005 vauxhall vectra
dog sets off alarm on vectra
2009 vauxhall vectra cdti how do you know if alarm is set alarm
disable vectra c alarm
