Results 1 to 2 of 2
Thread: What HID in my vectra?
    Essex
    Default What HID in my vectra?
    Hi , I have a 55 plate (new front end) vectra and I'm not sure what type of HID bulb I have - there seem to be about 3 or 4 types from searching the net.
    Also the colour display says check low beam left - does it descriminate between bulb failure and the strike (ballast) unit?
    Can this be test using an op-com fault reader?
    Any help would be much appreciated
    Regards
    Richard
    BOX
    Hi your dip beam will be H7. If you buy a kit, Standard are 4K for best light 6K are ok. Anything else is more blue ting and less light. make sure the kits come with the special clips to retain bulds in the new style fittment that is on all new VX fro 2003.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
