Thread: Oil Change Info Please
    Hertford, Hertfordshire
    Question Oil Change Info Please
    Hi to all Vectra C owners,
    time to save some cash I think, so Iv'e got to do a car service myself.
    Something I have not done in some years, and as I now work part-time at a Motor Parts shop ( Staff Discount ) on parts is great.
    I also kept all my Snap-on tools from my Karting days, so with help of a Haynes Manual I am going to get my hands dirty again.
    However can someone tell me the size of ( Sump-Plug & Oil Filter Housing ) nuts, my Vectra is a Feb 07 1.9cdti ( 120bhp ) Exclusiv.
    Thank's, Andy H137
    Regular Member mattolly86's Avatar
    oxfordshire
    22mm ring i believe but im sure its between 22mm to 24mm gotta do a full brakes, oil and coolant leak on mine and a glow plug next month oh joy
    Regular Member Pete B's Avatar
    Malvern
    32mm for the oil filter housing - a moulded hexagon on the end of the housing. Can't remember exactly for the sump plug, I just selected the correct one from my socket set but IIRC, 14 mm or thereabouts.
    Vec C Facelift 2006 1.9CDTi 150 SRI
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Mine was 32mm for the filter and a 16mm for the sump plug!!
    preston
    I'd get yourself a new sump plug before you start aswell, they are not dear. Mine was chewed to bits trying to get it off as the hexagon is smaller in diameter than the sealing face and I ended up chiselling mine off as posted on here.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    my DTi has a torx 40 sump nut, and the oil filter top was a 37mm socket, but im not sure about the CDTI's
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    did my CDTI the other week, 32mm on oil filter housing, access is quite restricted. I managed to reach mine over the top of the engine bay, you can get more turn on the ratchet that way. Only partly undo the filter housing, theres a drain off spout. Let it empty the filter housing before you complete remove it. The oil will drip onto the exhaust so throw some rags onto the exhaust pipe.
    The oil sump is a 13mm socket, but these can round off quite easily, so replacement is a good idea, last time i did it i had to whack a 12mm socket over the top of it. When you tighten it up its not supertight only 20nm.
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    cheers plasma got to do mine this week too and new front disc and pads
    Apr 2009
    bromsgrove
    sump plug is 13 mm i would always use hexagon socket rather than multipoint, much less chance of rounding it off .(use a bar dont whack it!)
    oil filter is 32 i think , messey things they are . i have only changed them on a ramp and that is awkward enough, i use a spanner but you can only move it a little at a time with oil dripping down your arm and all over the exhaust , you can just crack it open and take off the rubber bung and let oil out of filter housing but this seems to take ages and you still get the oil all over the exhaust etc,i prefer to get the filter out as quick as poss to get the mess over and done with .
    have fun..
  1. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Oil and Filter Change info needed
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 14:00
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
  5. Anyone with TIS - Cambelt change info ?
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2007, 22:39
37mm vectra oil
