Results 1 to 10 of 14
Thread: heater problem
    playing with spanners
    Default heater problem
    my heaters dont work on number 1,2 and 3 setting and does on number 4 ,
    had a search on hear and i just dont understand about relays and that
    so could anybody explain what it is that broke and how to fix it in realy simple terms ,
    thanks
    Full Member Big Sig's Avatar
    The resistor pack has probably got wet and needs replacing. Its near the heater motor somewhere. Thats the most common fault it seems with symptoms like you have. HTH
    WGAF#5
    the reason it only works on the last settting is because the resitor that controls the "blower" has burnt out and eventually setting no 4 will not work as well as this is the highest point of resistance
    the resistor may well be corroded from a water ingress as this was a known issue on the earlier pre face lift c's whereby Condensation water from blower motor accumulates at bottom of blower motor housing ( rust formation etc. ).= Resistor is damaged.
    and the fault was prevalent upto 2006
    following the replacement of the resistor check resistor and blower motor for water marks or rust. if present then Drill a 4 mm hole at the lowest point of the blower motor housing (brush area) when the blower motor is removed. this will allow the water to drain away - if theres none present then the resistor has just burnt out and is quite common
    linky to 11 page similar probs and how2 locate that nasty little resistor
    http://www.vectra-c.com/forum/showthread.php?t=21620
    atb
    Dez
    Regular Member andymcniven's Avatar
    newcastle upon tyne
    With mine it was not the resistor pack but a small blue relay that is located behind the glove box to the left hand side , remove your glove box and operate your blower switch , you will hear the click as number 4 is selected .
    Remove the relay open it up and give it a blow out then manually operate it then put it back together .
    stick it back in and try 1,2,3 it worked on mine and cost nothing to fix
    newcastle upon tyne
    check out this link towards the bottom of page 2 is the fic without being to technical
    http://www.vectra-c.com/forum/showth...heaters&page=2
    milton keynes
    have you unplagged the heaters recently , because if you dont put the black connector back on , it will also give this fault.
    Regular Member cameraman's Avatar
    Leicester
    Had this fault on the wife's Polo, was just the resistor pack on hers but it was a right pita to swap, the heater motor was behind the glovebox, but I had to strip the interior out starting with the centre console.
    thanks everyone , fixed it now , was the resistor
    WGAF#5
    Ron,
    burnt out or corroded ??
    Ron,
    it all looked ok so i dont know mate ??
  1. Heater problem help
    By squeeze76 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 10:35
  2. Heater problem
    By kirstylt in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 20:16
  3. Heater problem, help please
    By spandy234 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2010, 17:36
  4. heater problem
    By rickeys16v in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2010, 02:34
  5. heater problem
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 00:00
