Thread: new starter motor
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Default new starter motor
    I Have had a new start motor fitted and since then when i start the car for the first time in a morning it comes up with the spanner light then goes off after about 30 seconds car drives fine and i dont see it again untill the next day. is there any reason for this
    Regular Member mattolly86's Avatar
    oxfordshire
    hmm could be a range of problems does it only do this when the car is cold?
    Nov 2005
    scotland
    If its a diesel it could be a faulty glowplug
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    i have only noticed it when the car is cold and it is a 2.0DTi
    Nov 2005
    scotland
    Their is a good chance it is a glow plug - Any good garage should be able to test them.
    You can use a multi meter.
    Unplug the connector of the glowplug.
    Measure between the terminal and the cylinder head.
    The meter is set to measure resistance in Ohms. A measured value of less than 5 Ohm is indicative of an unbroken heating coil. A measured value of more than 5 Ohm (usually extremely high or infinite) is probably indicative of an open circuit and therefore a damaged coil.
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    i dont get paid for a couple of weeks will it cause the car any problems running like this until i can sort it
  1. Starter Motor?
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 15:18
  2. Starter motor help.
    By 123rado in forum Engine & Drivetrain
    Last Post: 6th January 2012, 21:30
  3. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  4. Starter Motor
    By Steeev in forum Engine & Drivetrain
    Last Post: 15th September 2008, 16:56
