Results 1 to 10 of 15
Thread: Help help help urgent
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Help help help urgent
    Parked signum down hill with still 50 miles showing on tank got into take to petrol station and it conked out.
    I have put nearly 10 litres in but the car starts for 5 seconds and then dies again
    what can i do? help urgent
    ps: signum 2.0 Dti - pre facelift
    Nov 2007
    Leeds
    Anyone?
    Regular Member GAZWAH's Avatar
    darlington uk
    try some easy start in the intake to get it running....sounds like a air problem! fingers crossed anyway...ps any eml on?
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    air in the lines or a blocked fuel filter. id try reving the tits off it as it starts.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Is it still parked on a hill??
    Try getting it to level ground then try again!!
    Nov 2007
    Leeds
    turning the crap out of it think my battery might go soon...
    the car is on a level now as rolled it out of the drive so the fuel tank has registered nearly 1/4 tank now but still wont start!
    easy start i cant get any at this time i dont think plus doesnt that make your car addicted to it like a junkie?
    is their a bleeding technique? would it make a difference if i took the fuel filter out and back in again?
    Regular Member WHOOSH05's Avatar
    On the back wheel
    you should never use easy start try cracking the injector pipes off to bleed it.
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    does it start enough to rev? i revved the tits off mine when there was an engine management problem and it seemed to clear whatever was blocking a sensor.....give it a try
    Oct 2007
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    i remember changing the fuel filter in my car and in doing that the car took a while to start. jst pumped the gas and turning the key. eventuly burst into life.
    Regular Member adfrodsham's Avatar
    lincoln
    Quote Originally Posted by Darryl2.2DTI View Post
    same with me
  1. Urgent help with 2.0t .....I'm under it now
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 18:28
  2. Need urgent help
    By cbetts2005 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 01:07
  3. Urgent help!
    By Kieran1981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2009, 19:17
  4. urgent
    By jones20002uk in forum Engine & Drivetrain
    Last Post: 21st April 2008, 17:10
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
