Thread: Swirl flaps
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Swirl flaps
    can anyone with a cdti 150 tell me if when reved light'ish (tickover to 2-2500 rpm) if the swirl flap rod moves, the reason i ask is because im sure mine never use to, and ive never noticed it before, obviously you would have to get someone to do this while you watched, i thought it only worked with boost!, for the record the engine was at running temp, and was working fully with any amount of revs ???
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Mines does not move at all - although it broke off the motor link doesnt.
    It only works under 5 Degrees as it is for cold starting m8.
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    no mate it works all the time with engine boost, but i was'nt sure wether it worked with low engine revs as im sure it never used to?
    Belfast
    Gazza 4's reply is rubbish (sorry!). The inlet should open at about 2-2.5k. It's got fig-roll to do with temperature and even less to do with boost.
    The swirl flaps close at low revs to close one of the two inlet ports, which makes the incoming air swirl around the combustion chamber. At higher revs, the swirl isn't needed, so the flaps open letting both inlet ports do their thing.
    Same idea as Twinport on the petrol engines, and the older dual-RAM on the old V6 and I-6 lumps in Omega/Carlton.
    More details at:
    http://en.wikipedia.org/wiki/Variabl...ntake_manifold
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by _ZS_ View Post
    Gazza 4 and the-wizard's replies are both rubbish.
    A bit strong there - I was told by a mechanic that is it to with pre-heating and Wikipedia - seriously? Thats your basis of information and sharpness
    Gazza4
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 18:34
  3. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  4. Swirl Flaps Pt 2
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 18:43
  5. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
