Thread: Weee Question
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Question Weee Question
    Can anyone tell me please where the Boost Pressure Sensor is in the 1.9CDTI 150? Also what would be best for cleaning it? Carb cleaner? Gonna give the EGR valve a clean too whilst im at it as the car is not as responsive as it once was.
    Cheers guys for any help
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    i would give the egr a good clean NOT forgetting the hole that it fits to on the engine, it usually gets virtually blocked! and you will find it will make a big improvement.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers m8
    Gonna get some gaskets aswell.
    Gazza4
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    hello mate,
    if you take off the plastic engine cover
    locate the egr valve, move to left you will see a little black box connected to engine block with one torx screw (has a blue sticker on it) thats the boost sensor, disconect the plug, undo screw pull out
    and it looks like a grain of rice in a cage, be very carefull when cleaning
    when i did mine i got from halfords some 3in1 heavy duty foaming cleaner
    great stuff sprayed it in my EGR valve and on end of boost sensor, its like shaving foam leave it on for 5 mins rinse off with wd40 or similar and it came up spotlesss
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Grimo72 View Post
    hello mate,
    Cheers bud thats a gr8 help thanks
    Gazza4
  1. MOT Question
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2011, 12:54
  2. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  3. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  4. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  5. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
