Thread: Help with boiler required..
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default Help with boiler required..
    when we run the hot water tap the boiler does'nt always fire up to supply hot water, (this has just started happening) if we turn on the heating then we turn on the hot tap the water runs hot, heating on its own is not a problem.
    Boiler is a 10 year old Vokera maxin 28 combi..
    Anybody got any ideas.
    Regular Member gromit's Avatar
    Cumbernauld
    My boiler had the same problem ans it was a small rubber diaphragm that was perished. I think it cost me £20ish for the new one and I changed it myself. See if you can find the installation manual online as mine had a fault finding section and I used it to diagnose the problem.
    Feb 2007
    Durham
    ive still got the manual although i dont know how after 10 years, will have a look through it now.. will also check diaphram..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Failing that the water flow sensor could be nackered. Again only about £20
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    hi had same problem. replaced dhw diaphram cost about a fiver. If you change it yourself make sure you remove all traces of old diaphram and put some SILICONE grease onto the rod that actuates the micro switch. You wil need to turn off cold water supply to boiler and open the lowest cold tap to drain it. Hope this helps
    Feb 2007
    Durham
    i've ordered a new diaphrgm today £2.54 + vat hopefull that will sort it.
  1. Noisy Boiler
    By crispy007 in forum General Chat
    Last Post: 21st November 2011, 18:52
  2. Gas boiler broke? or is it?
    By spoons in forum General Chat
    Last Post: 22nd September 2010, 13:46
  3. Help with boiler required..
    By dh.dti in forum The 'Off Topic' room
    Last Post: 1st August 2009, 13:22
  4. any boiler guys here?
    By gallag in forum General Chat
    Last Post: 5th May 2009, 19:44
  5. Boiler Advice
    By leeds vectra in forum General Chat
    Last Post: 9th February 2007, 00:47
