Thread: safe on cd player
    inverness
    Default safe on cd player
    how to i get my cd plyer to work again disconnected battey then it is saying safe on the lcd it a tape deck with cd changer aswell all in the same unit
    Wolverhampton
    you need to put your radio code in if it is an older model.
    inverness
    05 plate
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like the ccr2006, you'll need the code. It should be on a card with the handbooks
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Turn car off
    Press and hold AS button whilst turning car to 3rd click
    It will beep
    then entre the code
    only using digits 1-4
    if the code is 1 2 6 9
    You press 1 till 1 apears
    you press 2 till that apears
    and 3 till thats the same (6 times)
    And 4 (9 times)
    When all 4 digits are in press and hold AS again till it beeps it will then auto tune
    HTH
    5 Post(s)
    Quote Originally Posted by andymagee1982 View Post
    Turn car off
    That doesn't sound right.
    The correct procedure is:-
    Turn Off Stereo
    Switch On Ignition (No Need To Start Engine)
    Turn Off Stereo again (if it comes on with the ignition)
    Press & Hold Preset " AS " and Switch Radio On - Display Shows " SAFE " And Then Shows " 10 - - - - "
    Press preset " 1 " repeatedly for 1st Digit
    Press preset " 2 " repeatedly for 2nd Digit
    Press preset " 3 " repeatedly for 3rd Digit
    Press preset " 4 " repeatedly for 4th Digit
    If the correct code number is now shown Press & Hold Preset " AS " Until the Unit Beeps
    May 2008
    Widnes.
    Ha just wrote it better than me but still the same thing hope he sorts it out
    inverness
    yeh sorted it out cheers read the handy manual ha
  1. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  2. cd player gone in to safe
    By chrisssy in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 21:11
  3. Safe
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2011, 02:30
  4. 05 vec sri cd player saying safe????
    By jaff in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2008, 22:56
  5. Is it okay to / safe to
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2006, 11:15
