Thread: can any one anwser my ? please
    inverness
    Default can any one anwser my ? please asap boost sensor
    just cleaned the boost sensor on my vectra dti just wondering it had oil on it as i am clueless with dti cars was just wondering if that is normal if not what is it doing there and what could be the problem help would be very greatful asap
    thanx all
    inverness
    Default can any one anwser my ? please boost sensor
    hi all just cleaned boost sensor valve had what i think is oil mite be rong dont know much bout dti as just bought it is oil ment be there if not anyone know why there and what the reason for it
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    just had a look mate and yes it should be there hope it helps
    inverness
    few wicked thats aload of my mind thought there was more rong with it
    when going along dual car hits maby 70 at bout 3000 rph then stupid spaner comes on the dash got told to clean that then disconect battery for 30 mins,,so hoping the problem sorted know of anything else if not there no burst pipes as i can see
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    it should be ok now mate just see how it goes if no better let me no
    Nottinghamshire
    I have the 2.2DTi and have also noticed oil - or something that looks like oil - in the airways/pipes. I don't know if this is supposed to happen, but you're not alone. I'm sure someone will be along soon who can enlighten us.
    inverness
    nuh still the same roblem 3rd gear and dies around 3000 rpm
    noticed that there was a broken vacum pipe one them wee thin things if that could coz it also sounding realy stupid now radio saying safe on it from me disconnectin battery any way getting it working again cheers for the help m8t
    inverness
    yeh been told on another page that the oil is ment to be there worry over on that aspect ha
    Nottinghamshire
    The instructions to enter the code into your radio are in the audio manual. You will need the credit card-sized passcode card which has the radio security code on it, along with quite a few other codes. If you don't have this, you will need to get the codes for your car from your dealer - take proof of ID and proof of ownership of the car.
    For your error light, first check all vacuum and air pipes are secure and un-damaged - cracks, splits, loose, etc. The air hoses are available as a set, and the vacuum hoses and the rubber ends are sold by the metre.
    Failing that you may need a new boost sensor - cleaning it doesn't always do the trick. First I would get the fault code read because this will help to pinpoint the problem, and could save you spending £60 on the boost sensor when that's not actually causing the error light.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As james said have your fault codes read .
    inthe meantime check all the vacuum hoses for splits and cracks.
    Try removing the egr valve and cleaning it , have a look in the how 2 section for instruction on this . all these areas will give you similar fault s
    and still loving it
