Thread: Computer help - Packed Generic.200
    northampton
    Default Computer help - Packed Generic.200
    Hi Everyone, We now have a Packed Generic.200 virus on our computer. Nortons picked this up but was unable to fix the problem. Tried to restore but not successful. We have windows XP and nortons 2009. Could anybody help with resolving this virus
    Would really appreciate your help.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Had one of these myself recently, nasty little thing, took me ages to get rid of it completely. Depends which variant it is as the "Packed Generic 200" listing is simply that a generic type of trigger.
    First thing to do is turn off system restore and then download, install, update and run a full scan with Malwarebytes (http://www.malwarebytes.org) and see what that comes up with. In a lot of cases this will completely clean it in one sweep, however some of these are really nasty and even Malwarebytes can't completely clear them.
    Check all your harddrives for hidden files called autorun.inf and delete them (these are normally used on CD's legitimately to run the disc automatically when you put it in, however some viruses use these on hard drives to re-infect every time you open your hard drive in explorer). Ideally before you delete them all, open one in notepad and you should see the path to the file it's triggering when it runs which will also give you a pointer as to where the infection is and what it is.
    Also download RootRepeal (http://rootrepeal.googlepages.com) and anything it highlights in red in processes or files look them up on google (DO NOT just delete them, not everything in red will be un-wanted). Also check the services tab for any hidden services.
    Let me know how you get on and give any more details of what these find, giving names etc and I'll do what I can to help further.
    northampton
    Thanks for your help, I will give it ago later. The wife is dragging me out shopping for an hour. Will let you know how I get on.
    Jul 2006
    Somerset
    Another suggestion is to run Pandas free on-line scan - I find this great for removing viruses and has saved me hours of work.
    http://www.pandasecurity.com/homeusers/solutions/activescan/
    Click "Scan your computer now"
    If you install any programs to remove viruses then make sure you remove them afterwards, as you are running Norton it will cause your computer to be very slow due to them both scanning any files you open.
    If you are still getting nowhere, I would suggest you follow this..
    http://www.symantec.com/norton/suppo...080610152840EN
    It will talk you through running Norton in Windows safe mode.
    Feb 2007
    North west
    go to start / run and type cmd
    from the command prompt locate the directory and delete the file
    it will be stored at c\downloads and settings\owner\local settings\temp\ (and was named) "TDSS68dc.tmp"
    the system will work fine after removing this (run the symantec anitvirus stuff first and it deletes all except this)
    No pc repair too big or too small, Warrington, cheshire.
  1. Air con packed in.
    By johnseffs in forum Vectra C / Signum Troubleshooting
    Last Post: 6th October 2011, 16:24
  2. Any one with a generic map
    By Ziggy in forum Tuning
    Last Post: 1st May 2011, 13:58
  3. Original Parts VS generic/OEM
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 21:22
  4. Generic front grill from LMF
    By david.aka.judas in forum Styling
    Last Post: 11th March 2009, 22:58
  5. Are aftermarket HID bulbs generic?
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2009, 17:48
