Results 1 to 10 of 19
Thread: help
    Regular Member jonno_07's Avatar
    Apr 2006
    beverley
    Default help
    is the cr1 tuning box meant to come like that or should it have a box on it?
    any help is greatly appriciated!
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    It should have a box attached at the left hand end of the cable where the single male socket is. Contact your supplier mate.
    Looks like the module (box) is missing matey. Whoops!
    Apr 2006
    beverley
    i thought it didn't look quite right! there not working today and i want to see what its like!
    thanks for the help guys!
    Nicking Ya Dinner.
    Quote Originally Posted by jonno_07
    What do the fitting instructions say? it probably is missing the box, I cant say cos i've never really seen one, but modern progression makes things smaller, have a read and check it's not been incorperated in the left hand side if the loom.
    Looks like a bit of cable to me.... no "Box" there!!!
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by VauxVeteran
    I'm no expert on these things (not having a diesel) but in my limited knowledge there should be a box attached to the plug (as per Robbies post) - circled in red on the pic above.
    The other plugs are for the common rail connections to pass through.
    Dec 2005
    In the sponge-monkey tent
    Did you get mugged on FleaBay?
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    yes there should be a little black box on the end of the connector! it has the potentiometer on it so you can increase/decrease the setting for the fuel. the other two connectors just go inline with the fuel rail
    Apr 2006
    beverley
    Quote Originally Posted by Spikey©
    no its from diesel tuner!
