Results 1 to 10 of 13
Thread: gear stick top pulled off !
    Regular Member nigec's Avatar
    barnsley
    Default gear stick top pulled off !
    Just recoverd from a 3 hr session of drilling out a bust locking wheel nut, to going for a drive and then the gear stick head pulling off in my hands
    its been tapping for a week or so, pushed it back on just hope it decides to stay there. Oh these vauxhalls there just quality parts !!
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Mine did the same, it keeps popping off now.
    I might try a bit of araldite on it the next time it comes off.
    barnsley
    Might try some higher grade plastercene its got to be better than the standered stuff vx seem to use for the majority of the car parts !!
    Newcastle under Lyme
    Buy an after market one imo theyre only £30ish
    barnsley
    Off flea the bay ??
    barnsley
    Quote Originally Posted by JSYSH466Y View Post
    are these all a standered fit then ?
    as far as I know yes. They fit over the gear stick bar and theres an allen key underneath which you tighten. would suggest you tighten the bolt so it leaves a mark then slightly countersink that position so when you tighten next time it will not come off or spin. tbh I never had the problem without countersinking but if your unsure thats what to do
    Also make sure you get the pull up reverse kind
    barnsley
    Nice one cheers for that. Think my misses will agree to this mod as its a bit dangerous having a gear stick that falls to bits
  1. gear stick
    By caitlin6 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 20:54
  2. Gear stick
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 03:04
  3. gear stick
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 13th July 2012, 09:58
  4. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
