Thread: Infamous wipers DONT PAY VX heres a fix
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Thumbs up Infamous wipers DONT PAY VX heres a fix
    as most of us have had a problem with the wiper linkage and VX are claiming there is no problem, most of us have resorted to using tie wraps.
    I have now repaired mine and is going strong for the cost of about 25p.
    I didnt get pictures as I had my doubts on if it would work.
    I removed the assembly and drilled the ball joint in the center halfway down (using a pillar drill and vice) then tapped it to 4mm (not drilling through completely).
    I then drilled the socket to 5mm.
    Then using a machine thread bolt, a ptfe washer and a little thread lock put it all together.
    Its been nice to be able to use the fast wipe setting again and is very solid not clunking and slopping around like using tie wraps.
    Ok it might be a little more than 25p but still a damn sight cheaper than the cost of a new one.
    Hope this helps people.
    here is a crude drawing
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Well in mate, I did the same thing but on the car. When I screwed the screw in it snapped half way up the shaft. So now I have a pin in mine and with the plastic bag method has lasted me for months including the snow months.
    Apr 2009
    Kent
    Default Nearly the same
    I kept trying the cable tie method, and plastic bag method, but got nowhere.. so I followed the above lead..
    both ends of the passenger side wiper arm are coming off, so I've cable tied the bit where the two arms meet, but that pulls the other end off the top, so I looked to bolt that end down..
    I don't have access to pillar drill and I'm too tight to go buy a tap set ,so I just drilled straight thru..with a handheld drill...
    a couple of washers and a major pain in the ass trying to tighten a double nut setup later and I too have avoided the £155 cost that the local dealer wanted.. ( tried to convince me that I needed the new motor.. and didn't look in the mood for an argument..)
    The weak link now is either wear to the plastic ball socket or losening of the double nut, but we'll see...
    thanks for the idea Craig!
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Excellent tip
    Bent, my name is Bent
    Mods: I polished it in september...
    Liversedge, Westyorkshire
    whats the problem with the motors??
    belfast
    My linkage broke too, used a cable tie but that was useless so I got a jubilee clip from the garage, undone the clip, fed it round the linkage arms and tightened it back up. Havent had any problems for about 6 months so I think it could be a permanent fix.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    done the same on mothers agila 6 months so far all ok
    Apr 2009
    Bergen, Norway
    Could any of you please post a picture of the fix? Dont really understand what a jubilee clip is (Im Norwegian, so English can sometimes be a bit challenging), but Ill guess a picture will tell more than a thousand words
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    a jubilee clip is what's on you air pipes on you . silver with a 7mm bolt head or flat bade screw driver
    belfast
    This is a jubilee clip, I undone it, wrapped it round the two linkage arms and tightened it back up again.
  1. Infamous wipers
    By craigbarlow18 in forum Bodywork & Interior
    Last Post: 6th February 2009, 13:58
  2. Fuji GP Warning spoiler, dont look if you dont want to know!
    By rushy in forum Motorsport / Formula 1 etc. chat
    Last Post: 12th October 2008, 13:23
  3. anyone on heres car
    By pogo in forum General Chat
    Last Post: 14th October 2006, 09:54
  4. Im New And Heres My GSi
    By 3.2_V6_VXR in forum Quick Photo Album
    Last Post: 25th September 2006, 22:24
  5. Duncan.....you're infamous!
    By MLC in forum General Chat
    Last Post: 17th December 2005, 16:23
